I recently purchased a new 2019 C-HR, LE trim level. I have purchased 17 inch aftermarket alloy wheels with an offset of 35 mm. My understanding is that the factory spec for this car is 45 mm. If I use the tires received on the car at purchase (215-60-R17), will this cause any interference or steering issues. Approximately 3/8 inch more offset than factory steel rims.
How wide did you go on your wheels? I went with 8" with a 40mm offset and the stock tires clear with no problem. The section width of the tire is dead even with the front fender and the narrow tread width allows for plenty of clearance.
