Recently I'm hearing a rattling or a kind of vibration sound in the passenger airbag area. It happens at nights when the weather is cooler and when AC is on. Especially, when I drive on bumpy roads. During the day I don't hear anything.
Does anyone have the same experience?
Should I check the Airbag area or AC compartment?
Thanks.
Isn't your car still under warranty? If you can reproduce the problem consistently, I wouldn't mess with anything and just bring it in to the dealership for them to figure it out. This does a couple of things. One if they may have a tech which has enough experience to quickly figure out what is causing the problem and fix it at zero cost to you. Second, if the problem isn't found, you've documented it as a problem in the service history of the car. So if it keeps happening or gets worse, you have a complaint history; especially if this continues into the warranty being expired.
Reactions: Striker
