21 - 23 of 23 Posts
I went with the WOLO anyway. I hooked a relay to this one as the wattage is too much for the OEM wiring. It was just like doing the same on both my RAV4 vehicles. Although I had to remove the bumper off again later on both to install front radiator guards.I used the pre-painted guttter mesh and zip-tied them to the inside of the bumper.
If you are going to change the horn, follow the procedure. You need to determine where the original car horn is located. Usually, it is behind the radiator grille, under the fender, near the battery, or in another under-hood recess. Before starting the disassembly work, you should disconnect the battery terminals. Then disconnect the power wires from the regular horn and perform its disassembly using the Highest quality components. Made mounting a new horn and connected the power wires to the horn. After connecting, the battery signal should work.
21 - 23 of 23 Posts
