Not sure if there are any threads on installing the OE mud flaps/splash guards. The Toyota part number for the full set is PU060-10016-P1.
I found instructions on the UK C-HR site which had absolutely no resemblance to the mud flaps I received. I seem to recall some discussion by those that did do the install there was only one hole needed to be drilled on the rear mud flaps. This was not the case with the mud flaps I received. If I recall correctly, I had to drill 3 holes on each side of the car for the rear flaps. And I had to drill 2 holes on each side for the fronts.
With the additional mounting hardware required, the flaps are held onto the body work extremely well. I'm not sure if there was an update to the mud flaps due to some problems. And this may be the reason why when I inquired about possibly ordering the mud flaps from my dealer, the parts guy said there was a stop sale order on the flaps.
Anyways, here are some pics of the attached mud flaps.
Sensitive content, not recommended for those under 1846.5 KB Views: 346
