I've checked air pressure in all 4 tires and they're fine. Light won't go though. It came on last winter once and they went off itself. This year, fist night below 10 degrees Celsius and light came on but this time it forgot to go off
Do i have a bad sensor? Any way to check myself or do i need to go see the dealer?
2018 c-hr xle premium
Super Moderator
I'd try resetting the TPMS system again. There's an option in the center dash menu to reset/resync the TPMS sensors in the wheels. If that doesn't work, then it's time to take it to the dealer. Unfortunately, there's no way to determine which sensor is bad since the system doesn't tell you what the individual measured pressures are...at least none that I'm aware of. You need a scan tool to figure out what's being reported back.
