Hi there, I installed the HID kit to replace the LED today; however both side of headlights are flickering right now...(Xentec 35W). Did you guys install the relay harness with your HID conversion kit? Thanks!!
Thanks! I'll check it later today. :laugh::laugh:Check the grounding connection. Most HID kits are sensitive for poor connections especially the grounding wire from the ballast.
I'm thinking of installing HID kit too! Was it hard to install it?Hi there, I installed the HID kit to replace the LED today; however both side of headlights are flickering right now...(Xentec 35W). Did you guys install the relay harness with your HID conversion kit? Thanks!!
It was VERY VERY easy to install on C-HR, just plug and play. I checked with the seller, and C-HR doesn't require a relay harness for 35W HID kit. But I found some negative review for this kit and decided to order another from another brand. I will take some photo while installing the new one.I'm thinking of installing HID kit too! Was it hard to install it?
Please keep us posted and send some photos if possible.
Did you use a relay harness for these?Easy. I bought these on Amazon Sept 18, 2017. Installed two days later.
"Innovited AC 55W HID Xenon Conversion Kit With "Slim" ballast - 9012 - 6000K - 2 Bulbs & 2 Ballasts"
https://www.amazon.com/dp/B00Y0261D4/ref=cm_sw_r_cp_apa_f8FhAb51AQHFW
Installation was Plug and Play. 10 minutes max. Nice and bright! No flicker. I get the high beam flash rarely from oncoming traffic. There is no dead spots as I had when I tried the led version...
Thanks!It was VERY VERY easy to install on C-HR, just plug and play. I checked with the seller, and C-HR doesn't require a relay harness for 35W HID kit. But I found some negative review for this kit and decided to order another from another brand. I will take some photo while installing the new one.
I bought the Xentec and it was flickering. So I google the best HID conversion kit, most of the reviewers suggested Kensun HID. Now, mine Kensun is shipping from the US to Canada. I will write a review of the Kensun after I installed it.Thanks!
By the way, can you please share the link where you got that kit. I found a few options on eBay and Amazon, but want to compare them to what you ordered.
