Hi all
Im wanting to install a stereo amp to my chr 2018. Can anyone advise me on how to pass the power cable through the fire wall please.. recommended grommet to use.
Thanks in advance all
For my 2020 I had to use the only grommet I found...which is right behind the battery to towards the left. I used a blade to cut a slit and pass the power wire through.
So i made a start routing the cable for my project. I could not get to the grommet i wanted tocuse. So went the door route.
After putting the cable through the plastic grommet i used rubber sealant so to create a good seal.
I used cable ties to keep the cable secure.
More pictures to follow
Interesting...in my case i was working with 4 gauge so i doubt it would have worked. As a sealer i used thin rubber sheets w/adhesive backing.
