Looking at the C-HR maiontenece log, not much needs to be done to the car every 5,000 miles unless you go off-roading with the thing. Most of it is just inspecting fluid levels, wiper blades, brakes, and rotate tires. Then every other visit if to change oil and fluids.
I decided to check the logs after reading somewhere online that the spark plugs in general should be changed out around 30,000 miles. That's not the case here because it only has to be done when it fails or at 120,000 miles/144 months.
