I impulse bought a big brake kit from ProdigyWerks and it is for the front only. Where can I find a kit for the rear or at least calipers? Just found out that I need brakes all the way around after driving pretty hard for 73k
I doubt you're going to find an upgraded rear brake calipers with the electronic parking brake set up on these cars.
I'm curious as to why you felt you needed a BBK for your car? I don't know if ProdigyWerks did any testing as to see if their recommended BBKs will work with the stock braking bias using the stock rear calipers. You should ask them. I would also consider seeing if you can get a refund. Unless it's for looks, I really don't see a need for a BBK on these cars. I think you'll get as good (maybe better) results by using upgraded brake pads.
Reactions: RoLleRKoaSTeR
