1 - 9 of 9 Posts
So the 20,s with tires weigh 56 lbs per corner. The stock 17,s weigh in at 48 lbs per corner. I gain weight but look better.
My sizes for referance are 20 x 8.5 +40 offset with a tire size of 245 35 20
With this set up my overall diameter is equal to the stock 18 inch tires used on this car. And the wheels sit flush!!.
Rims look great, and I agree that with a slight lowering, everything would look very clean. I suppose that's dependant on whether or not this vehicle is being used in the winter. Sometimes its better not to lower the ground clearance. I wonder if you'll notice and different in power with the weight gain. Let us know how it rides.
Discussion Starter · #7 ·
No rubbing whatsoever. Lots of clearance. I may do a 1.5 inch drop on suspension. As for the 40 lbs you wont feel that in performance its negligable. Handling is improved due to the lower profile side wall . A bit more road noise but thats due to the cheaper brand tores i baught.
1 - 9 of 9 Posts
